newbee with trans problems
Old Dec 14, 2005 | 08:57 PM
scootertrash's Avatar
cool site! hope someone can help! i have a 97 lesabre with the 3800 automatic a\c bla la bla has about 110thou miles
problem; trans does not shift into gear when you first start the car. meaning when you shift it into reve. 123d doesn,t engage after a good warm up it shifts fine? whats the deal?
also im gonna change the fluid becuase it smellsbad [not really burnt] but thin as well. i few inputs; where somehting about a seloniod sticking [wich one and where is it?] and whats a good way to get a good trans oil change converter and all a good flush?
ive been in the buisness of collision work for 30 years and do not even pretend to be a mechanic. i have a pretty good knowledge of the biznesss though1 ive built a chopper [127cu inch hardtail] and a 355 ci 400hp4spd chevy stepside
any help would e mmmmmmuuuccccccchhhho appreciateddddd!!thanks scootertrash![img]smileys/smiley5.gif[/img]
Old Dec 15, 2005 | 03:06 PM
kelcra259's Avatar
Well the tranny fluid does need to be changed. Any tranny specialty shop would be a good place to go. What I do, or have, is an old compressor from a freezer to use as suction. I stick a line through the fluid check tube and start of the compressor. This way it is less of a messy job, plus I can get up to 2 gallons or 8 quarts out during a fluid change because the fluid is warm, not hot and the vehicle is on ramps or inclined.
If you do not want to take it to a shop any change is good.
Old Dec 16, 2005 | 10:32 AM
[img]smileys/smiley14.gif[/img]thanks for the heads up i really appreciate it! gonna try that compressor thing thanks agian,scootertrash
Old Dec 16, 2005 | 02:13 PM
Patrick's Avatar
Administrator
also, most corporate shops (monro, meineke, etc) can do power flushes...i would recommend a power flush..not just a drain and refill
Old Feb 3, 2006 | 01:13 PM
SSEBonne90's Avatar
The jusry is out on power flushes, Some for Some against it.
Old Feb 3, 2006 | 09:22 PM
i did the hose down the filler tube got 8 qts, change the pan gskt.and filter
found a small metal line running into what appears to e a modulator of some kind,
anyway metal pipes are only press fit and one was out so i don,t know if the fluid or the tube, fixed the problem but it works a ton better now still has a little hesitation in reverse, but its much better and another change is in the very near futureit can,t hurt!
i want to thanks all you guys for all the help! scootertrash in houston texas "ya,ll come see us hear!!"[img]smileys/smiley4.gif[/img]
Old Feb 6, 2006 | 05:50 PM
kelcra259's Avatar
Good deal. Even thought they are fitted lines, you can replace with proper transmission hose and use two clamps on either end. I replaced my lines by cutting off the end with the fitting going to the tranny cooler on the radiator and put on new hose with two clamps. Works great. Glad we could help.
Old Jul 27, 2006 | 11:36 AM
orevgym's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Use Amsoil in your tansmission, see what that does.
Do a fuul flush(torque converter too) and new filter, gasket.
let me know
1glock17@bellsouth.net
SnakeBit
Nov 19, 2013 05:02 AM
pk74
Nov 10, 2012 12:45 PM
VmanC
May 19, 2011 11:24 AM
tandtb
Jan 24, 2009 03:48 PM
blackhat
Jul 10, 2006 10:17 AM
