directional signal lamp
Old Jun 8, 2011 | 12:23 PM
Hal's Avatar
Hal
Default directional signal lamp
I have a 2002 Buick Regal Custom.
1) How do I change a directional signal lamp? Instread of going click - click , It races click,click,click, etc. on turning left.
Thank you. Hal
Old Jun 8, 2011 | 02:28 PM
Have you determined if it is front or rear?
Old Jun 9, 2011 | 07:54 PM
Hal's Avatar
Hal
Default directionl signal lamp
It's the front, left side.
Old Jun 10, 2011 | 05:35 AM
The bulb number is # 4157NA. Its an amber colored bulb.
The headlight assembly generally has to be removed by lifting up the retaining tabs that secure it to the front assy. Then remove a rubber separator cover and the signal lite bulb should be just below that, easily seen. Pull out the old bulb and install the replacement one. Assemble in the reverse order.
Old Jun 10, 2011 | 12:44 PM
Hal's Avatar
Hal
Default Signal lamp
Thank you very much. Hal
Old Jun 10, 2011 | 04:12 PM
You're welcome ! Would like to know if you were able to get the bulb changed. Thanks
Old Jun 12, 2011 | 09:19 PM
Hal's Avatar
Hal
Default Directional signals
I opened the hood and looked around - how cramped. I examined the outside and decided it was too complex for me. I thought I could just change a light bulb, but at 85 years old, I guess I can't.
I'll take it to Sears tomorrow and have them install it.
I appreciate your help. Thanks Hal
Old Jun 14, 2011 | 10:50 PM
Hal's Avatar
Hal
Default Directional signal lamp replacement
The lamp was $4.99. Labor was $42.50. Time expended by mechanic -between 5 and 10 minutes. Unfortunately they wouldn't admit non-mechanics into the shop area so I still don't know how he did it.
Maybe I can download a video or sketch of how it's done. It's awfullly expensive and I'd like to do the next one myself.
AT the same time, you splend $15 - $20,000 for a car and you can't even change a light bulb. Maybe the designers need to go back to the drafting board and make this operation simpler. Perhaps it's just me.
My turn signal works now. Thanks for the help, Hanky.
Hal
Old Jun 15, 2011 | 04:54 PM
  #9
I believe there is a "method to their madness". It goes something like $42.50. Don't worry, once you learn how it's done you won't need to do it, I can assure you, it's not you!
Oilpatch197
Apr 17, 2011 09:49 AM
fun2b1
May 14, 2010 07:21 PM
AARRTTBuick
Dec 5, 2007 06:28 PM
Michail
Nov 20, 2007 10:26 AM
sixty7rs
Dec 7, 2005 03:16 PM
