fuel gauge
Old May 2, 2013 | 11:48 AM
millwright69's Avatar
Question fuel gauge
'01 le sabre limited The problem i have is that the fuel gauge just shows whatever it wants. is this just a sending unit going bad?just bought the car and this is the only problem with it. any help will b appericiate.
Old May 2, 2013 | 02:56 PM
Not knowing what kind of tools you have available or your ability to lift and get under the vehicle, What should be done is to check all the wiring connections at the fuel tank plug and see if the same readings are obtained there. If the poor readings are confirmed at the tank wiring plug , it would most likely be a faulty sending unit in the tank.
MrBSS
Nov 13, 2006 12:18 PM
rzad
Oct 11, 2006 01:44 AM
Dave626
Jul 8, 2006 11:54 AM
Dave626
Jul 7, 2006 06:49 PM
gbliss
Jun 25, 2006 12:21 PM
