1989 Buick Skylark starting problems...need help!
Old May 2, 2010 | 12:31 AM
253ICF's Avatar
Default 1989 Buick Skylark starting problems...need help!
Why does it only start when the weather is warm outside? When its raining or cold outside, it starts then dies after a few minutes. It also sputters when its trying to start in cold weather. Is this problem easy to fix or will I need to take it to a mechanic ?
Old May 17, 2010 | 11:55 PM
johncarry's Avatar
Car thinks it is in reverse and won't start. Shift it to park, or adjust linkage so the reverse light switch is not engaged. You may have a colapsed motor mount and the engine/transmission are out of position causing the linkage adjustment problem.
Old May 19, 2010 | 01:39 AM
Samohajo's Avatar
There's a small single wire on the starter that ignites the starter ,check it for power when someone turns the key to start the car there should be 12V,if no voltage check wire for burnt,worn or cracked sign's and replace if nessasary
mikebruce700000
Oct 23, 2012 09:06 AM
Franklin_Phil
Nov 10, 2008 10:35 PM
Orton43
Apr 29, 2008 07:58 PM
BurntCornMuffin
Jun 20, 2005 01:51 AM
89buicklesabreL
Apr 27, 2005 10:10 PM
