1988 Electra wont start
Old Jan 13, 2020 | 05:21 AM
Menigen's Avatar
Default 1988 Electra wont start
Hey, i have a problem with my 1988 electra. It was working fine and all but then we opened the right rear dorr and the engine just stopped. Ever since that we havent got the engine running again. It cranks but will not start. The fuel pump is working and i have changed the coil pack but we do not get any spark from it. Please help.
Old Jan 18, 2020 | 09:27 AM
The door incident may be a coincidence.
You didn't state whether all the fuses were checked or not.
Tests need to be done to confirm the signal is coming from the crank sensor , which could be the problem since you replaced everything in the line to provide spark, except the ign sw. It can crank with a defective sw and still not start.
Old Jan 18, 2020 | 10:03 AM
Menigen's Avatar
All fuses are checked and none was broken. Can it be something with the security system that is broken?
Old Jan 21, 2020 | 04:55 PM
If the battery is located under the back seat, you might have to lift up the carpet and door sill and you might see a cable there that supplies power to the engine compartment.
Detra319
Feb 8, 2010 06:49 PM
regal88limited
Jan 15, 2009 11:45 AM
nissantech25
Aug 19, 2008 02:23 PM
rajidae
Mar 13, 2008 06:08 PM
mrscarto
Feb 3, 2007 06:14 PM
