95 Roadmaster Automatic A/C
Old Jun 28, 2021 | 10:50 AM
bocoogto's Avatar
Default 95 Roadmaster Automatic A/C
Yesterday, my HVAC fan stopped working--no previous noise or malfunction. I can manually operate the fan speed control, and it shows bars added as the speed control is increased, but the fan does not respond. I realize the fan motor is under the dash, not easily accessible. Anyone have some troubleshooting tips?
Old Oct 5, 2021 | 08:44 PM
Fred Kiehl's Avatar
Remove the fan and apply 12 volts across the leads in the connector. Be careful, if the fan starts, it will try to rip it out of your hand. You can also check the fan fuse. You need a 5.5mm socket to remove the fan. You must remove the door sill, and kick panel to get to the bolts. If the fan is toast, I have a couple of used OEM ones for $80 shipped. You can get aftermarket units, but the fan is about 3/8 inch too short, and will not push as much air, because of the leakage over the top. I also have a pigtail that will attach to the fan so that it does not require removal to check it. I would like $10 shipped for one.
damngood vehicle
Dec 11, 2020 12:14 PM
beaverplt
Jan 21, 2020 04:44 PM
feltes94
Jan 20, 2012 01:55 PM
steener
Feb 24, 2010 12:03 AM
Dave
Jan 17, 2006 08:03 PM
