92 Regal starting problems
Old Feb 19, 2012 | 08:24 AM
mikebruce700000's Avatar
Default 92 Regal starting problems
Hello! I have a 92 Regal that won't do anything when the key is turned. All the lights and bells work, the solenoid just won't click. I replaced it maybe two months ago. also, the voltage does not drop when the key is turned. I can't jump it off either. Over the last few days, the car has done this, but started after two or three tries. Any ideas?
Last edited by mikebruce700000; Feb 19, 2012 at 09:49 AM. Reason: additional information
Old Feb 19, 2012 | 03:15 PM
I would suspect the ign switch assy.
Does it make any difference if you try to start it in park or neutral?
Old Feb 20, 2012 | 07:32 AM
Park or neutral doesn't make a difference. I thought about the neutral safety switch too, but would like to be able to bypass it to test it. Do you know which pins on the relay base to jump? Or can it be done with the Regal? I get home alte, so it's kind of hard to work underneath to check it. Also, do you know which wires on the ignition to connect if bypassing the switch to test?
Old Oct 21, 2012 | 01:42 PM
Junkyardjames87's Avatar
I think you may just have to look under the car where the starter wires are and check and see if they are loose or corroded. Mine were on my 93' Regal and just wiggled them a little and now it fires right up almost every time (just not when really, really cold like -45f).
Old Oct 22, 2012 | 07:20 AM
Yes. I fixed this back in February. There were wires to the starter that had broken and frayed. Spliced them together and she was good as new. Sold her a few days later.
Old Oct 23, 2012 | 09:06 AM
Unhappy Ok now im havine a problem
OK any ideas about my 93' regal that almost wants to die before it'll start when it's really cold but when the motor is warm it takes a couple of tries to start. Cold starts are kinda easy but a warm start takes two to three pulls. And the service light is on and I'm getting kinda crappy gas mileage.
253ICF
May 19, 2010 01:39 AM
Franklin_Phil
Nov 10, 2008 10:35 PM
Orton43
Apr 29, 2008 07:58 PM
bennyg
Dec 20, 2007 06:03 PM
BurntCornMuffin
Jun 20, 2005 01:51 AM
