2001 Buick Regal air flow stuck
Old Sep 9, 2012 | 10:19 AM
Braath Waate's Avatar
Default 2001 Buick Regal air flow stuck
Just a heads up. A common but easily fixed problem with older buicks is that dash air flow control stops working. This is usually because the vacuum line that runs over the passenger side wheel well that is part of the vent control system becomes abraded and then eventually plugs right under a wire cable near the battery tray. I had this problem and found the solution on repairpal.com. I just cut out the bad section and reconnected the line for a zero cost repair. My guess is that this problem will likely happen to all buicks of this era if they are run long enough (mine has 230k miles).
Old Oct 11, 2012 | 01:55 PM
SwitchPitch's Avatar
Good info. Thanks.
It's added to my list.
Paul
Ray_M
Sep 29, 2024 03:42 PM
peshewa
Jun 13, 2014 08:53 PM
Jimmy Smith
May 20, 2014 10:18 AM
feltes94
Oct 25, 2012 10:38 AM
dwallbaum
May 3, 2006 03:08 PM
