2003 Buick Lesabre leaking clear fluid
Old Nov 2, 2019 | 04:47 PM
Dylan Thomas Perry's Avatar
Default 2003 Buick Lesabre leaking clear fluid
Hi, I have a 2003 Buick Lesabre. This afternoon, I noticed a large amount of clear liquid leaking out the bottom of the engine, on the passenger side. It seems to be dripping out from underneath the crankshaft. It looks like water, and I don't smell much, except when I get really close it smells... dirty. Not sure what this could be, any help would be appreciated! I have a couple pictures of the leak location. It might be worth noting that my heater stopped working about three weeks ago, and I had the transmission replaced just a few days ago (but it really doesn't look or smell like transmission fluid) and I didn't notice any leaks until today.
Old Nov 3, 2019 | 02:18 AM
That seems like quite a bit of fluid..
With the weather you folks have been having could it be just condensation from the exhaust?
Have you had to add any coolant?
If the source cannot be immediately seen, we usually will apply some pressure to the cooling system and see if the pressure (15 lbs) drops and a leak becomes more visible..
Old Dec 19, 2019 | 09:53 PM
Frampton1007's Avatar
Default Fix it ??
Did you find what it was that was leaking? Waterpump???
Old Dec 21, 2019 | 08:20 AM
I think Frampton had a pretty good idea there. What was the conclusion ?
Old Dec 21, 2019 | 09:26 AM
Or heater core... But usually that will leak inside the car, but it would be on the correct side.
kdmitchell2776
Aug 1, 2017 06:22 AM
awbooth
Mar 21, 2012 08:01 AM
MikeS67
Apr 18, 2009 01:41 PM
