1995 Buick Lesabre, V6 Antifreeze smell.....
Old Mar 18, 2012 | 06:48 PM
awbooth's Avatar
Default 1995 Buick Lesabre, V6 Antifreeze smell.....
We are getting an antifreeze smell coming from under the hood and working its way intothe cab. Water pump was replaced some time ago, no antifreeze leaks at the hoses, thermostat housing or the water pump..... Couldit be the heater core? Would we get antifreeze in the cab if the hesater core has a leak? Please help, can't stand the smell!
Old Mar 18, 2012 | 08:00 PM
Yes, you would get the odor of anti-freeze in the passenger compartment. One way you might confirm this would be when you turn on the defrosters it blows moisture up on the windshield.
Old Mar 19, 2012 | 05:04 PM
awbooth's Avatar
I checked the compartment, no smell, coming from under the hood only, what do you think? Can't find any leaks but smell antifreeze for sure!!
Old Mar 20, 2012 | 02:15 PM
If you can smell it , it's there. Look for green or white deposits on the engine usually when anti-freeze gets hot it leaves a deposit in the area. Could be the water pump seal or just a hose leaking because it's loose. If you can't find anything, best to have a shop put some pressure on the cooling system , that usually will expose the leak.
Old Mar 21, 2012 | 08:01 AM
awbooth's Avatar
ok, sounds good, I'll check the hoses!!
bandit_60
Jan 19, 2015 11:20 AM
filthy1
Dec 29, 2013 04:49 PM
kevinh
Nov 25, 2010 12:33 PM
lola502
May 4, 2005 11:27 PM
