1996 check engine light
Old Jul 13, 2006 | 01:02 AM
mhtuba's Avatar
I just purchased a nice 1996 LeSabre Limited. Condition of the sale was the check engine light needed to be fixed. I just brought the car home, and it's on again. The car runs great (I haven't had it long enough to tell about mileage). I'll be taking it back to the dealer who sold it to me (129K miles) - but I wondered if anyone out there has had similar problem. No oil leaks, egine runs smoothly. Guy claims they replaced the intake manifold gasket and water pump.
Anyone out there doing their own OBD II work?
Old Jul 13, 2006 | 08:47 AM
samueljackson's Avatar
obd2s are a lil more sensative than the first obds. there are more parameters that will trigger a code.
did u try lil stuff first, gas cap wuld be my first guess.
but if u have a light coming on, then u have a trouble code or codes, what are they???
Old Jul 14, 2006 | 09:34 AM
mhtuba's Avatar
Thanks for the reply - one of Audi tech sons is bringing home an OBD II tester, which I hope sheds some light on the problem. The gas cap is a good idea - NJ insepction failed me for a bad one a few years ago on another car - I guess they lose their seal after a while.
When we fix it, I'll post the results here.
Old Jul 14, 2006 | 06:06 PM
mhtuba's Avatar
The scanner turned up problems with the O2 sensor (before the CAT) and the Mass Airflow Sensor. The MAS is a little pricey, so we'll probably change ouyt the O2 sensor first - under $60 here in NJ. The scanner he borrowed sells for around $150 on the web - although cars throw some screwey codes, this might be good investment. The socket is right under the dash inside the car.
We re-set the codes, and will check it again after the check engine light comes back on.
Should help the MPG when we're done with this.
noblesaints
Aug 3, 2011 03:54 PM
wadeshaff
Apr 5, 2010 07:30 PM
BonnevilleGXP
Apr 11, 2008 09:13 PM
BPA1986
Mar 15, 2008 10:43 AM
TINNER73
Oct 10, 2006 12:58 PM
