2008 Buick LaCrosse telescoping steering column lock lever won't stay up
Old Aug 31, 2019 | 01:23 AM
  #11
JBGauge's Avatar
Originally Posted by hanky
You may still need to remove the covering and do a careful check. While there you will most likely see why the lever won't stay put.
To be sure, I know this. I just don't want to start taking things apart without having a good idea what I'm getting into. That's another reason I wanted the exploded view diagram. It would also be nice if it were possible to obtain an exerpt from the factory shop manual describing how to adjust the clamp on the telescoping steering column. Pretty sure the screw only came out from the lower cover. The broken part piece though, that's a real head-scratcher.
Old Sep 2, 2019 | 01:00 PM
  #12
JBGauge's Avatar
I just made a major discovery that might help other people. The steering column I have isn't described as being capable of tilt and telescoping, the actual phrase is "tilt and travel". Doing an internet search using those terms will be far more productive.
Johnny Cee
Aug 25, 2019 04:43 PM
JJK64
Feb 17, 2011 02:58 PM
Karmabit
Dec 28, 2009 06:00 PM
Micahphone
Feb 9, 2008 06:29 PM
copternut
May 17, 2007 09:46 AM
