ODB2 faults, 3 of them
Old Feb 9, 2006 | 05:02 PM
jzadovsky's Avatar
Hello,
I have 1996 Buick regal 3.8L (live in CA).
The car has 181K miles on it. I cleaned the MAF and EGR units allready.
I keep getting the following ODB2 faults.
P0102, P0401 and P0441.I know what the books says,
but I need additional information on the root cause.
The car idles a little ruff and when I get on the freeway or driving on a grade at freeway speeds. The car will stutter/ hesitate for a moment.
The Check engine light also comes and goes.
I can not accept that I have multiple sensors that are bad, but which
is the bad one.
thank you
Juan
I'm new to this site and still learning about how to use it
Old Feb 9, 2006 | 11:13 PM
kelcra259's Avatar
I have a lesabre with the same engine. I had the same issue. Turned out to bet the TPS. I also cleaned the throttle body. Seemed to help.
Old Feb 10, 2006 | 03:07 PM
jzadovsky's Avatar
What is a TPS? and where is it located on the engine
thanks
Old Feb 10, 2006 | 03:38 PM
jzadovsky's Avatar
Is the TPS a Throttle Position Sensor.
Can I remove it and clean it or do I have to purchase a new
one.
thanks
Old Feb 10, 2006 | 04:24 PM
kelcra259's Avatar
Yes that is correct. On mine located no the Trottle body near the MAP Sensor. You cannot clean it. Sensor is not too expensive.
Old Feb 10, 2006 | 06:23 PM
jzadovsky's Avatar
How does the TPS sensor cause all of the above faults.
Why does not the computer catch the fault at TPS itself.
I will purchase a new one, I just like to know?
Something else my car does, with the car in PARK, I rev the engine
to 4000 RPM and the engine starts to stutter.
Thanks
Juan
Buick Forum Editor
Dec 1, 2014 04:09 PM
firefightermaness
Headers, Intake, & Exhaust
Jul 23, 2009 07:05 PM
