hard cranking starts
Old Jul 19, 2008 | 09:38 AM
vince48's Avatar
I Have a 2001 Buick LaSabre and it takes three times of cranking to start the engine. This occurs when the engine is hot or cold. I have replaced the battery and fuel filter and the problem still exists. The spark plugs were changed about 1 year 2 months ago with about 36K miles since the change. The engine seems to start easier when I have a full tank of gas? Any suggestions?
Thank you!
Old Nov 8, 2008 | 01:59 AM
BPA1986's Avatar
I had the same problem and it ends up the fuel pump was almost shot. So get the pump checked. That could explain why a full tank would help start the car, less pressure on the pump. Hope this helps!
Old Nov 9, 2008 | 05:46 PM
Rusty's Avatar
check those plugs also, I know 36K isn''t alot but take time to look at them. The fuel pump sounds right, could well be it. Let us know.
schzjoe
Jan 24, 2013 07:55 AM
kbdwh
Jul 7, 2008 10:28 PM
cjthor
Apr 15, 2008 03:33 PM
MNM3461
Apr 3, 2007 05:35 PM
stone
May 25, 2006 12:59 AM
