sluggish starts
Old Jul 3, 2008 | 10:46 AM
kbdwh's Avatar
I have a 2000 buick park ave. It used to start instantly but now it cranks for about 30sec. then you have to step on excelorator and then it will start. I''''m thinking fuel problem. you can hear the fuel pump run for about 3 sec. then shut off.I listened for this three times this morning to see if it would startbetter, but it didnt help. Can anyone give some advice??? Edited by: kbdwh
Old Jul 3, 2008 | 02:18 PM
samueljackson's Avatar
i agree, it sounds like a fuel problem. Could be signs of a weak pump, or dirty injectors. I would check the pressure. check at prime, idle, and WOT.
Old Jul 3, 2008 | 03:47 PM
kbdwh's Avatar
Do you think its the pump? It never misses a beat on the road even if you step on it hard. What do you think of the pressure regulator, I read if you pull the vacuum line off there should not be any fuel in it. I pulled it off and it was full of fuel. Is this true.
Old Jul 3, 2008 | 04:31 PM
replace immediately. there should be NO fuel in the vacuum lines. I dontknow ifyours falls into the recall that 98 and 99 L36 engines had, but I would call the dealer to check for you. there have been explosions of the plastic intakes due to this fpr failure.
Old Jul 7, 2008 | 03:16 PM
kbdwh's Avatar
Did some research on the recall and it was in effect.had the dealer change the fuel pressure regulator. It starts just fine now. Thanks for the info!!!
Old Jul 7, 2008 | 10:28 PM
good to hear. those free dealer fixes are rare, but great! That park ave is a great car, and will last you a long time if taken care of right.
skarnley
Dec 9, 2008 10:52 AM
vince48
Nov 9, 2008 05:46 PM
cjthor
Apr 15, 2008 03:33 PM
MNM3461
Apr 3, 2007 05:35 PM
stone
May 25, 2006 12:59 AM
