06 Lucerne cxs rear electronic struts/shocks
Old Aug 2, 2018 | 01:41 PM
Robert McColeman's Avatar
Unhappy 06 Lucerne cxs rear electronic struts/shocks
Need to replace as they are 12 years old and are leaking. Told that they can only be purchased through GM Canada at $1250 a piece.
Can these parts be purchased aftermarket in the US. and what do they cost in USD ? What is the best brand to buy.?
Old Aug 3, 2018 | 04:46 AM
Darn? For an over decade old car I'd replace with the closest non-adjusting shock to accomodate driving habits. Or the manual setting adjustable shock set. Ford in 2013 didn't have that option and on my other car can adjust with manual settings (have these days of coarse).
The only time setting is changed is for tracking or drag strip. Can set rear struts softer for shifting weight to rear tires as fulcrum for traction. Other than that why would anybody even bother- Leave magnaride shock replacement for next owner?
Amazon Amazon
Old Aug 3, 2018 | 06:35 AM
Some folks form quite an attachment to a vehicle.
Depending on the strength of your "attachment" will most likely determine which path to choose.
If just a means of getting from here to there , I believe the lowest cost replacement is a good move, but if on the other hand if this is your baby, you might search around for decent replacement parts. What do you think?
Old Aug 3, 2018 | 06:54 AM
Thank you for the advise. What brand of replacement parts would you go with. ?? I plan on keeping the car for many more years.
Old Aug 3, 2018 | 07:05 AM
You would have to shop around on the net because I don't if all manufacturers make those specialized parts.
There is , Moog, Monroe, AC Delco (origional eq) and a few others.
Old Aug 3, 2018 | 10:38 AM
Thanks hanky
ill do some research and let you know how the project turns out. Regards R
Rich B.
Feb 11, 2018 03:04 PM
wnlewis
Sep 27, 2011 07:40 PM
olhounddog
Mar 21, 2011 05:16 PM
NittanyLion
Jul 27, 2009 10:39 AM
