hi low beam switch
Old Nov 29, 2008 | 09:17 PM
wworrall's Avatar
where is the high low beam switch located and how hard is it to change? re: 1991 Buick Park ave.
Old Dec 4, 2008 | 08:34 PM
Toadster25's Avatar
It is about half way down the steering column on top of it. There is a rod that connects it to the lever when you pull on it. It is kind of hard to change if you''ve never done one. You will probably have to lower the steering column down to be able remove it and then it has to be adjusted to work right since it is slotted.
nhawlman
Aug 18, 2009 07:30 AM
Michail
Jan 2, 2009 06:54 PM
michigan man
Feb 26, 2006 12:36 AM
michigan man
Jan 19, 2006 08:42 PM
Unick82
Sep 9, 2005 01:48 AM
