99 Century Driver’s Power Window
Old Nov 10, 2005 | 01:06 PM
rklueber's Avatar
window works when it wants. will go down all by itself. it used to take a couple of switch actuations to get it to work, but now it hardly works at all. motor? controller? switch? I have no clue & the dealers & parts outlets are no help. The parts are very expensive & not returnable!!!! HELP!!!!!!!!!!!!
Old Nov 10, 2005 | 02:32 PM
Patrick's Avatar
Administrator
you mean that it literally goes down by itself? or the switch only works once in a while?
Old Nov 11, 2005 | 11:45 AM
rklueber's Avatar
The window does both - goes down by itself & works when it wants, which now is very seldom.
Old Nov 11, 2005 | 04:18 PM
Patrick's Avatar
Administrator
when it goes down, does it go down as if you were making it go down, or does it just sort of drop?
Old Nov 11, 2005 | 05:13 PM
rklueber's Avatar
It goes down just as it should if you activated the switch.
Old Nov 14, 2005 | 02:24 PM
Patrick's Avatar
Administrator
wow..i would think that it has to either be in the switch, or there are wires grounded agaisnt each other, activating the window. have you tried removing the door panel, and seeing how everything looks? something else you could do, get a switch that works, from a junkyard,or just by any switch at a parts store. remove the panel and run the switch wires to the new switch, and see if it works, if so, its your switch.
reel effort
Jun 5, 2019 10:10 PM
JoeCole
Sep 20, 2008 07:10 AM
buickman
Jul 23, 2006 05:02 PM
Dragonrider99
Feb 13, 2006 04:27 PM
