mass air flow
Old Jul 22, 2012 | 05:10 PM
feltes94's Avatar
Default mass air flow
i have a 2000 buick regal ls where would io be able to locate the mass air flow sensor ?
Old Jul 22, 2012 | 08:11 PM
I'm not 100% sure where it is on the 3800. If it's not by the air box, it might be a part of the throttle body.
Old Jul 23, 2012 | 05:07 PM
To help locate the MAF sensor just trace the air intake tubing from the air filter assy.
It is located between the air filter and the throttle body.
Just look for a black box type assy with three wires going to it .
Old Jul 23, 2012 | 06:05 PM
feltes94's Avatar
ok thank you i found it also i was thinking about putting a cold air intake on but they do not make one for a 2000 buick regal and also what is in the air box besides the air filter?
Old Jul 23, 2012 | 07:05 PM
IAT, Intake air temp sensor.
Old Jul 24, 2012 | 07:02 PM
The PCM (computer) is in the air box. You can just zip tie it to where the air box mounts, or you can pick up a PCM tray from a Blazer/S10 and install that.
Old Oct 25, 2012 | 10:38 AM
Merc6's Avatar
The S/C intake kits work on N/A Regals/Centuries depending on where your coolant over flow and washer fluid tank is located or relocated.
peshewa
Jun 13, 2014 08:53 PM
Jimmy Smith
May 20, 2014 10:18 AM
Braath Waate
Oct 11, 2012 01:55 PM
DavidC77
Nov 8, 2011 12:50 PM
oldnew
Oct 25, 2004 11:30 PM
