2004 Regal Air Filter
Old Sep 29, 2004 | 01:46 PM
oldnew's Avatar
Hi,
My 2004 Regal's (10000km only) air filter is kindof dirty.
It is an[OEM]oily paper filter and everything sticks to it, be it dust, insects or other stuff. Of course, the dirt is stuck mainly where the air intake is, (the rest of the filter looks clean).
The question is, should I replace the filter ?
tia
Old Sep 29, 2004 | 02:26 PM
Erakiel81's Avatar
If you can see the ligth through the air filter and if your car doesn't
take more fuel as usual you can continue a while with it.
Have you compared with a new filter ?
Old Sep 29, 2004 | 02:33 PM
oldnew's Avatar
If you can see the ligth through the air filter and if your car doesn't take more fuel as usual you can continue a while with it.
I'll try the "light method" . Even though I'm a little skeptical because the filter is oiled and therefore more opaque.
I went to Canadian Tire to get a new one but they had none.Anyway, CT only sells regular [un-oiled]paper filters so I cannot compare.
Guess I'll change it anyway [when I find one].
Edited by: oldnew
Old Oct 25, 2004 | 11:30 PM
oldnew's Avatar
I wonder, what if the dealer sprayed some "engine-look-good-to-sell" stuff while the engine was running ? That might explain the oily look'n'feel.
Anyway, I've changed the air filter and run some Motomaster injector cleaner through the fuel system and the mileage improved from 14.7mpg to 16.8 (i.e. 16l/100km -> 14l/100km) all city driving.
tvsdprasad
May 21, 2015 06:40 AM
Merc6
Nov 13, 2011 07:13 PM
Strids97
May 15, 2008 07:34 PM
ahardb0dy
Jul 16, 2006 02:02 PM
redv8dak
Feb 23, 2006 03:43 PM
