2003 LS *adding gs supercharger*
Hi, i recently just bought my 2003 Regal LS and wanted to get the GS supercharger in it. Just what would i need to add to it for a complete swap,lets say we start fromjust the LS motor alone, Include what i would need. Thanks,any information would be Greatly wanted.
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I thought through this several times for different cars. In the long run, you are better off selling this car and just buying the GS w/ supercharger. You get so many more items than just the upgraded engine - such as transmission, brakes, suspension and or interior trim upgrades (leather steering wheel)
Do the math to convince yourself. If you sell the LS and buy the GS, can you do the swap for this amount? I'd suggest getting the GS, and change the trim to show "LS badging "...
Hi jerrywc01! I have the same problem and I think your input is such a help. Thanks.
_________________
jason07
Dual Diagnosis Treatment --Learn more about dual diagnosis treatment options
</span>
_________________
jason07
</span>
Now that's a different idea. I couldn't fully answer that question but imagine sensors would need changing, fuel injectors, pulley sizes, tranny reprogram and on. The entire CPU would req. a stock program. My point being everything to go supercharged would have to be reverted. Intercooler removal if car has one, pressure relief for overboost may be a problem or part of supercharger.
I'd look for a new supercharger, the Buicks weren't rated that much more supercharged, today the power is there minus charger. http://www.automobile-catalog.com/pe...ercharged.html An example, not much to work with but going backwards? Good luck on project.
oriley_adam
Jun 11, 2007 06:42 PM
01, 03, 2003, add, buick, dropping, gs, ls, put, regal, supercharged, supercharger, supercharging, swap, upgrade
