1998 25th anni. electrical problem
Old Jul 10, 2006 | 01:52 PM
BuleJay10k's Avatar
There I was, getting off the Jersey Turnpike to 295 to skip a few tolls, cheap bugger that I am. Power window down, interior lights on to read the ticket of course, see how much I owed, radio on some station playing low. Suddenly...blink...all interior lights go out, radio goes off, window won't go up. I crank that little lights **** to the right and the lights don't come on like they should, but an indicator on the dash says "door/trunk". All other systems are go, but I have to drive my dang car from Trenton to Baltimore with the window down, not to mention park in Baltimore with the window down. And let me tell ya, you've never had an 18 wheeler thunder past you doing 90 on the jersey turnpike until you've done it with the window down.
Anyone know what happened?
edit: 126000 miles
Cheers,
AK
Edited by: BuleJay10k
Old Jul 11, 2006 | 05:22 AM
samueljackson's Avatar
did u chech any fuses. the instrument lights are only fused. the power windows have a relay as well as a fuse.
Old Jul 11, 2006 | 11:44 AM
BuleJay10k's Avatar
It was a fuse, all three were hidden under the "Interior Lighting" fuse. Next question, squeaky brakes. They're 2 weeks old, didn't squeak at first, but then they started. And they don't squeak all the time either, just sometimes at very low speeds and sometimes when braking hard at very high speeds.
Andrew
Old Jul 13, 2006 | 08:51 AM
when u say the brakes are 2 weeks old, do u means u changed the pads 2 weeks ago, or did u replace the rotors as well?
did u use the caliper lube?
did u use shimmed pads?
did u clean ur guide pins?
did u use brak-clean when u were done?
VanBuren
Apr 19, 2024 04:41 PM
Firefighter48
Jun 4, 2013 07:50 AM
Firefighter48
Jun 3, 2013 08:09 AM
67 455 Bird
Oct 28, 2008 07:31 PM
linkinparker445
Nov 13, 2006 10:37 PM
