2007 LUCERNE 12v Accessory Outlet Replacement
Old Feb 18, 2013 | 09:00 PM
Sarge6th's Avatar
Default 2007 LUCERNE 12v Accessory Outlet Replacement
I have an 07 Lucerne with center console that the accessory power outlet has stop working. How do I remove to replace?
Old Feb 20, 2013 | 03:35 PM
Before beginning replacement, would be a good idea to look in owner's manual and see which fuse protects the power outlet and check that fuse. Let us know what you find.
Old Feb 20, 2013 | 07:44 PM
Sarge6th's Avatar
All fuses are good. That was first thing checked. Based on owner's manual, all power point are on the same fuse. Could there be an in-line fuse?
Old Mar 25, 2022 | 08:29 PM
jstone2066's Avatar
Default Same problem
I have the same issue, have you found the problem or a solution?
Old Mar 26, 2022 | 01:09 PM
What needs to be checked and this can be done with a simple test light or multimeter.
Verify power and ground are present at the receptacle.
If both are present ,there is a problem with the plug that is getting inserted into the power point receptacle.
jstone2066
Mar 25, 2022 08:35 PM
Mako_99
Aug 25, 2018 05:09 AM
acfeldman100
Apr 2, 2018 07:53 AM
Dogping
Apr 9, 2009 07:35 AM
rckrchrdsn
Dec 7, 2008 11:37 AM
