high idle problem 94 lesabre
Old Aug 24, 2010 | 07:55 PM
TLW64's Avatar
Default high idle problem 94 lesabre
94 lesabre 3.8 liter has high idle codes read quad driver failure, replaced idle air control valve but did not fix problem . vehicle will run high idle and when you turn engine off and try to restart you may have to wait 10 to 20 minutes before engine restarts . can unplug mas air flow sensor and vehicle will drop down to low idle but surges. any help would be greatly appreciated
Old Aug 25, 2010 | 01:21 PM
TLW64's Avatar
just wanted to let everybody know i replaced the ecm and that solved the problem with the vehicle it also solved the no speedometer problem that the vehicle had .
painkiller
Feb 20, 2007 01:55 AM
kelcra259
Aug 5, 2006 10:03 AM
billimpala
Jul 9, 2006 06:39 PM
msdelin
Feb 7, 2006 03:24 PM
