high idle at start
Old Dec 30, 2005 | 12:47 PM
msdelin's Avatar
I have a 93 Lesabre with a 3.8 V-6. Intermittantly when I try to start the engine it will not start in the normal manner. After turning the key a second time I have to press the accelerator to the floor and then the car will start, although rev up to 2000 or 3000 rpm. After a short time the rpm's will drop to normal idle.
This problem does not occur at any particular interval that I can determine or any particular set of circumstances such as setting for any length of time. When this occures it will happen for the next several attempts at starting and then will not happen for a week or so.
If anyone can help it would be greatly appreciated.
ps. There have been no repairs to the vehicle at this time attempting to correct the problem.
Old Jan 2, 2006 | 03:01 PM
Patrick's Avatar
Administrator
has your fuel mileage been very bad? when was the last time that it was tuned up?
Old Jan 3, 2006 | 10:24 AM
msdelin's Avatar
The fuel mileage has not had a noticabel decrease. It has been a while since it has been taken in of r a tune up. I do most of the stuff myself. Plugs and wires were changed approx 2 months ago, battery is about 1 yr old. Fuel filter is new as of this weekend, air filter and oil change about a month ago (as a side note, I use synthetic oil), I use fuel injector cleaner in the gas every 3 or 4 fill-ups,
When I changed the fuel filter this weekend I also used carb cleaner and cleaned the MAF sensor and EGR valve. After doing this I have not had the propblem, however with it being intermittant I do not know if this corrected the problem or not.
Old Jan 5, 2006 | 04:06 PM
Patrick's Avatar
Administrator
well, hopefully that will clear it up for you...keep us posted.
Old Jan 25, 2006 | 03:10 PM
msdelin's Avatar
So far, as of today there have been no problems since the cleanings.
Old Feb 7, 2006 | 03:24 PM
joeski's Avatar
if it makes you feel any better, I have a 1980 Regal that does the same thing except I have to put the pedal to the floor or it will stay on high idle![img]smileys/smiley5.gif[/img]
Spri
Nov 11, 2012 03:01 AM
TLW64
Aug 25, 2010 01:21 PM
painkiller
Feb 20, 2007 01:55 AM
kelcra259
Aug 5, 2006 10:03 AM
billimpala
Jul 9, 2006 06:39 PM
