engine collant leak
Old Oct 16, 2010 | 06:28 AM
NFSRoadsta2786's Avatar
Default engine collant leak
i have a 1993 buick lesabre custom edition, n just recently i noticed that engine coolant was coming out of the mass airflow sensor, no this confuses me because of the vacuum that is produced when driving the car pulls everything in n the coolant is coming out of the throttle body need help
im thinking a broken gasket
Old Oct 17, 2010 | 05:15 PM
rayntx's Avatar
Default mainifold
check manifold cover, it might defective and replace it.
Old Oct 18, 2010 | 03:01 PM
Quite a few Buick engines are having a problem with the upper intake plenum (manifold).
The EGR system burns a hole in the plastic manifold and you experience coolant loss and eventually engine problems. Don't waste any time getting this corrected it could be quite expensive up the line. If this is the case with your vehicle , it's not too bad a job and doesn't have to be too expensive to correct if caught early. I am not positive this is your vehicle's problem, but it should steer you or your mechanic in the right direction if it is.
Old Oct 18, 2010 | 03:35 PM
Also I'm pretty sure that coolant does circulate through the throttle body .
miketx750
Mar 2, 2008 01:10 PM
sdsdsd
Jan 17, 2008 01:21 PM
JoeV
Oct 11, 2007 10:55 AM
dennysm
Dec 6, 2006 06:50 PM
oogy
Jan 5, 2006 05:15 PM
