Location of O2 sensor
Old Sep 29, 2018 | 11:06 AM
beaverplt's Avatar
Default Location of O2 sensor
Hi. I have an 05 Lacrosse V6 with a bad O2 sensor in bank 1 sensor 1. Can anyone tell me which one that is, as in where it is located?
Thanks
Old Sep 30, 2018 | 01:36 AM
Bank 1 is the bank on the engine where #1 piston cyl is located. Oxygen sensor 1 is the sensor in the exhaust pipe coming off of bank 1.
Always like to ask how it was determined the sensor itself was defective or malfunctioning. Many times we blame the sensor when it is working correctly.
Old Sep 30, 2018 | 12:42 PM
beaverplt's Avatar
Thanks for your quick reply. I have two trouble codes, P0053 and P0134, that both point to the O2 sensor at bank one, sensor 1. In other cars I've worked on the pattern of bank and sensor has been the same. I'm assuming that is universal.
Old Oct 1, 2018 | 03:23 PM
Yes, to the best of my little knowledge that is correct.
If you replace the O2 sensor and the code still comes up , might be a good idea to check the wiring.
Appears there is a problem with the O2 heater and the sensor not responding.
Old Oct 1, 2018 | 07:08 PM
beaverplt's Avatar
I usually check the wiring first. I had a code similar to this on my wife's VW that turned out to be the wire got snagged on something she hit and snapped. I doubt that's the case now, but since then, better safe than sorry.
ndecker
Mar 6, 2019 07:46 PM
Cam Rankin
Sep 4, 2017 02:54 PM
NotACarPerson
Jan 31, 2012 06:07 PM
PowerWagon896
Jul 7, 2009 03:56 AM
john harker
Jul 26, 2006 09:41 PM
