Front turn signal issues
Old Aug 21, 2018 | 06:39 PM
Mako_99's Avatar
Default Front turn signal issues
I have a 2011 Buick LaCrosse. I was putting in an oem nav/radio. Everything was working fine....now the front turn signals don’t work. Any thoughts on where to start? Yes I changed the bulbs first just to be sure that wasn’t the issue.
Old Aug 22, 2018 | 01:49 PM
Did you happen to be working around the fuse panel? Did you check the fuses?
Old Aug 22, 2018 | 02:21 PM
Mako_99's Avatar
I was working around the fuse panel inside. In fact I had a fuse go out because I was putting a switched power connection on a power outlet for the backup camera. I replaced that fuse. Through this process I have checked every fuse in the 3 main places (under hood, instrument panel, and trunk. The weird thing it is just these two front blinkers, nothing else. Normally that would point to a bcm but I didn’t mess with the bcm sat all.
Old Aug 22, 2018 | 07:00 PM
Have you checked the wires coming out of the steering column? The signal comes from those wires to the BCM.
Old Aug 22, 2018 | 09:50 PM
Mako_99's Avatar
Ill take a look at it. I didn’t touch any wires coming out of the steering column but I guess that is a good place to start
Old Aug 24, 2018 | 10:16 AM
Mako_99's Avatar
So I found out some more info for troubleshooting. The front bulbs come on when I turn the headlights on which rules out bad sockets. Use of hazards and left or right blinkers are the times it won’t come on. Hopefully this helps narrow it down.
Old Aug 25, 2018 | 05:09 AM
This may or may not be the problem.
First are you sure what is coming on with the headlights are the signal lamps and not the parking lamps?
Something you could check and that is the ground connection for the front lights. There could be a path for the heavier drain lamps to work, but insufficient for 1 lamp.
It's far out but needs to be confirmed.
Did you consider disconnecting the nav system and see if that might help?
acfeldman100
Apr 2, 2018 07:53 AM
oregondriver
Jun 22, 2016 01:46 PM
qman
Nov 3, 2011 03:56 PM
Dogping
Apr 9, 2009 07:35 AM
Turbo_Boss
Jan 30, 2007 09:09 PM
