Solenoid
Old Sep 30, 2021 | 07:42 PM
1950Sedanette's Avatar
Default Solenoid
My starter solenoid is non-functional. I have searched the net for a new one (Delco-Remy 1118019) to no avail. Someone please put me out of my misery and give me a clue as to who might sell them.
Jim
Old Sep 30, 2021 | 07:44 PM
I for got to mention my car is a 1950 Buick 43D.
Jim
Old Oct 1, 2021 | 06:38 AM
If there is a shop someplace near you that rebuilds starters and alternators, they should be able to assist you with locating the part you need.
Old Oct 2, 2021 | 12:29 PM
Wink I Did It
No one I can find sells or rebuilds old solenoids. I pulled the solenoid and isolated the problem. The coil that closes the points (relay) to activate the plunger coil was history for some unknown reason. I decided to pull that little coil by grinding the head off the rivet that holds it. I then epoxied a relay in its place and wired it to activate the plunger coil with a signal from the starter switch on the carb. Worked like a charm. Since I already had the relay, the job cost me nothing, and lends itself to future repair. I discovered the current day "alternator and starter" repair guys are just "pull and replace until it works" guys with little knowledge of how to actual repair anything. Sad.
Alexandru Balescu
Jul 14, 2019 12:04 PM
Marbil
Oct 15, 2018 06:10 PM
joey gossage
Aug 29, 2018 02:27 AM
wingnut
Nov 12, 2007 11:25 AM
