ses problem
Old Sep 24, 2012 | 01:16 PM
digimi's Avatar
Default ses problem
p1665 replaced gas cap and canister still trips ses with p1665 info please
Old Sep 25, 2012 | 01:27 PM
I believe this code involves the fuel evap system. There is an evap solenoid in the system that may be stuck, dirty or defective. Best to get a book for your particular vehicle to determine where it is located.
Old Sep 26, 2012 | 10:04 AM
digimi's Avatar
I replaced this, than I was about to pay to have a smoke test done and the light went off. I think it's an electrical problem. Electrical tape over the ses will fix this should it re-occurred
Now I need center caps for the rims and the location of the sensor for low washer fluid and it's on to happy motoring
Old Sep 26, 2012 | 11:24 AM
Good choice--electrical tape for electrical problem, cool !
You probably already know the sensor has to be in the washer fluid bottle. Tough one , aint it ?
Old Sep 27, 2012 | 01:25 PM
digimi's Avatar
Default low washer fluid sensor
you would think so hank my man,,, but that is not the case as I compleatly drained the bottle and no sensor. Was a time when it had a float system but I,m not seeing anything. Maybe I better go outside and take one more look. back at ya.
Old Sep 27, 2012 | 02:06 PM
digimi's Avatar
nope not in the tank,,,,,, so where is it//// up under the firewall where I cant see it ??? any info out there
Old Sep 27, 2012 | 03:39 PM
digimi's Avatar
oh there it is undersome where I can't see but I did find a diagram so anybody have experience changing this out???
Old Sep 27, 2012 | 04:36 PM
Manufacturers do some strange things and magnetic switches are one of them. Generally when a magnetic float gets close enough to the switch the magnet (affected by the fluid level) closes the switch and the low liquid level light comes on. The switch has to be next to or on the washer reservoir bottle. Most likely under everything where you can't readily spot it. Some systems just slide a plastic blade type switch under the bottle and there is a possibility you won;t have to empty the reservoir.
But as luck would have it you will need to remove the plastic bottle in order to get to the switch assy.Let us know how you make out with it.
Old Sep 28, 2012 | 09:54 AM
  #9
digimi's Avatar
I have found a diagram of s/w location and it looks like some "parts" need to be removed for acess. I have removed the resivor but I think it might be at the bottom of the fluid bottle which I can't see,,,,,,,without removing some parts. I havd a 95 riv setting in my yard back in wisconsin,,,,, and a cutting tourch,so now it's just a matter of time and pressure.
Old Sep 28, 2012 | 04:17 PM
  #10
digimi's Avatar
Looks like I just need to remove the inner finder, not a problem
Lesabre_91
Sep 28, 2012 08:09 AM
markdexter
Aug 5, 2010 10:30 AM
tosun28
Jul 8, 2008 11:56 PM
