P0446 code
Old Feb 26, 2011 | 03:19 PM
Larman's Avatar
Default P0446 code
I got this code on my 2002 buick century, 66795 miles any body had any experience with working this code?
thanks
Old Feb 26, 2011 | 05:51 PM
I means your vehicle has a problem with the Evaporation Emission vent system.
There are a few things that will cause this code to set.
A problem with the vent valve itself , electrical problem ie short to ground, short to power,stuck valve, possible PCM problem.
Did anyone just purchase fuel and not put the gas cap back on tight enough?
Old Feb 27, 2011 | 07:17 PM
Larman's Avatar
Default po446
No gas cap problem in fact when i went to loosen it and check the cap it was under a slight vacum. Do you think it is the vent valve solenoid? i took it out and cleaned the dust from it and checked the lines from the engine all the way back to the tank and could not find any thing wrong but i did not have a way to test the solenoid. Unfortunately you cant find that item at any store so it is a dealer item.
roughcreek
Oct 27, 2008 01:54 PM
kbunting
Nov 7, 2006 04:42 PM
samahi72
Oct 1, 2006 04:54 AM
ejb11
Aug 6, 2006 03:29 PM
javsam
Feb 24, 2006 08:46 PM
