High Engine Idle
Old Jul 7, 2006 | 03:12 PM
billimpala's Avatar
My car is a 1993 Buick Le Sabre with 75,000 miles on it with a 3.8 engine in very good condition except for one problem.About half the time I take my foot off of the accelerator, the engine has a very high idle.Thinking that it might be a vacume leak,I checked all of the vacume hoses for leaks, but they are all good. I replaced the IAC idle solenoid, but that didn't make a difference either. Sometimes the car will idle fine, but some times it can idle at up to around 2,500 RPM's. Any help would be appreciated. Thank You, Bill Eagle
Old Jul 9, 2006 | 06:39 PM
samueljackson's Avatar
get a tech 1 obd and make sure the tps sensor signal is between .33 volts and .47 volts. if the tps is out of adjustment it will fool the pcm to make a default signal. the tps is the most important sensor for timing the correct spark to fuel delivery. id check that first.
Spri
Nov 11, 2012 03:01 AM
TLW64
Aug 25, 2010 01:21 PM
painkiller
Feb 20, 2007 01:55 AM
kelcra259
Aug 5, 2006 10:03 AM
msdelin
Feb 7, 2006 03:24 PM
