Help 1961 Buick Waterpump leaking
Old Feb 1, 2023 | 04:11 PM
pablo Frausto's Avatar
Default Help 1961 Buick Waterpump leaking
Hi, I have a 1961 Buick special v8 and I have been having troubles forever. My water pump keeps on leaking even when I got one from the junkyard. It’s leaking from the gasket but I’ve used new ones and gasket sealant. What could cause my water pump to leak and it’s only leaking from one place.
Old Feb 2, 2023 | 09:59 AM
Are you sure it is not leaking from the water pump shaft seal and running down to appear coming from the gasket?
Old Feb 2, 2023 | 07:06 PM
When you mean shaft seal you mean the bearings, I don't think it's coming from there as its dripping from the left side. Do you know how to check if its the shaft seal thank you so much for replying?.
I can add a video of it leaking if that would help.
kdmitchell2776
Aug 1, 2017 06:22 AM
awbooth
Mar 21, 2012 08:01 AM
dws21396
Dec 4, 2007 07:47 PM
