Clanking & Scraping from inside of Engine
Old Jul 11, 2008 | 11:23 PM
scaryslow's Avatar
Hello,
94 Buick Le Sabre V6 engine.
It sounds as if afan blade is hitting something, or there are loose pieces of metal in a garbage disposal.
Even with Fans stationary.
Neutral, Park, Reverse and Forward.
The Belt is not touching anything.
Even when running for more than a minute.
When I took off all spark plug wires and turned the engine over, it never sounded good, a little grinding going on, but the clanking and scraping would sound off in the few seconds after I let go of the key as the engine came to a standstill.
It also sounds off after started, as mentioned above.
What could this be ?
Thank You
Old Jul 12, 2008 | 08:04 PM
samueljackson's Avatar
can you take any sort of video?
xrob
Nov 4, 2012 02:21 AM
aimee
Jan 9, 2009 05:42 AM
kmbc
Apr 14, 2006 07:17 PM
