churping noise
Old Aug 9, 2006 | 10:59 AM
TMKCH's Avatar
I have a 98 lesabre and it is making a weird noise. After 20 minutes or so of driving or idle it will start to make a "churping sound" then will start to make a loud squel (?). I have replaced the belt, pully, alternator and intake manifold recently. Belts are tight.I am not sure what it is was hoping someone could help me. My wife and I are on a limited income with 3 kids so would like to fix this without going to a shop. Also, could this be the transmission causing this or the hormonic balancer?
Old Aug 14, 2006 | 04:09 PM
Patrick's Avatar
Administrator
i have run into an issue recently with my fiancees truck which was very similar, and it was a NIGHTMARE..
turns out that it had a very slight coolant leak, and when the coolant would get onto the crank pulley, it would cause the belt to slip, hence the noise. i fixed the leak, and the leak seems to have gone away...its been a few weeks now *knocks on wood*
Did you do the intake manifold yourself? I know that these cars had coolant leak issues.
when it is squealing, and you sit in the car, with it running, and turn the wheel, does it change any?
djadkins
Aug 28, 2006 02:29 PM
gtrick
Aug 17, 2006 01:31 PM
TMKCH
Aug 12, 2006 08:11 PM
gtrick
Feb 3, 2006 02:14 PM
calvin
Jun 6, 2005 09:08 PM
