Changing light bulbs behind odometer
Old Sep 12, 2021 | 05:02 AM
MartinBorch's Avatar
Default Changing light bulbs behind odometer
hi, quick question before I do something wrong.
A couple of the light bulbs are broken. I have tried to see if I can get a hand up behind the entire box holding the speedometer/odometer etc (from below).
Not possible for anyone to get up that way from the floor and up. I have removed the glass cover and as you can see from the picture there are three small nuts holding the front panel. I can see that I also have to disconnect the thin wire which moves the gear indicator.
I am nervous that I by mistake disconnect the speedometer cable if I try to take away the front panel.
- and perhaps these light bulbs can not be removed from inside of the case.
Does anyone know,??
k6062007
Jun 25, 2025 02:28 PM
Bentwings
Jun 5, 2018 10:14 PM
Lord_Bryan
Dec 22, 2011 12:16 PM
Stardust
Dec 28, 2006 02:03 PM
Dave
Feb 26, 2006 10:12 PM
