94 century power windows???
Old Jul 21, 2009 | 09:05 AM
j-bob's Avatar
Default 94 century power windows???
Gotta 94 century special and the master switch went out inthe driver's door. Ordered a new one, but I cannot find a good enough wiring diagram to that tells me where each wire goes. My problem is that there are 3 sets of the same colored wire. (2-black, 2-brown, and 2-purple) I need to know how to check that I'm connecting the correct black wire from the module to the correct black wire in the door. Any suggestions?
Old Jul 28, 2009 | 01:24 PM
igneous's Avatar
Just look at wiring and label if needed while installing new switch. Or you can do 1 wire at a time. You may want to disconnect battery before starting this...at least have key 'off'/out (ie. not listening to the car radio while doing this)
Old Aug 14, 2009 | 11:15 AM
aidexia's Avatar
I can recommend to come on a site on which there are many articles on this question. не сочтите за рекламу, друг пригласил в новую космическую онлайн игру NetAssault - это просто БОМБА, а не игра:
Old Sep 2, 2009 | 07:24 PM
imp558's Avatar
Here's the plug pinout Bro,
Cavity Color Function
C1
A Black Ground for Illumination
B Gray Power for Illumination
H Violet RR switch
K Violet LR switch
L Brown Ignition power
C2
A Blue LF Motor
B Blue RF switch
C Black Ground
D Tan RF switch
E Brown LF Motor
G Green LR switch
H Lt Grn RR switch
Had to edit because I left out C1 A&B for Illumination
Good luck, Imp
buick38
Aug 20, 2011 04:48 PM
susie
Jul 20, 2007 12:40 PM
susie
Jul 20, 2007 12:10 PM
jedd
May 15, 2007 09:25 AM
bigdog472000
Dec 1, 2005 10:36 AM
