Power windows don’t work
Old Sep 21, 2005 | 04:44 AM
bigdog472000's Avatar
I have a 97 Buick Regal and the power windows don't work. I don't have a clue as to what's wrong. HELP.
Old Sep 21, 2005 | 02:17 PM
MrBSS's Avatar
So, no windows work? That probably means that the circuit is dead. Check the fuses and circuit breakers.
Old Sep 23, 2005 | 03:36 PM
Patrick's Avatar
Administrator
i agree..if Every window doesnt work, it almost has to be a fuse issue
Old Oct 21, 2005 | 11:52 PM
Harley's Avatar
yeah fuse would be the first thing to change, another thing, and this happend to may car. The switches for the windows, in my car there is a box on the drivers door, houses 4 2 way switches. well I guess it wore out or whatever, I grabbed another one out of a cadilac, cleaned it all up with contact cleaner, tossed it back in and it works good as new, that was over a year ago. But I knew it was the switch pannel cause each window (4 door) would work by it's switch, but none would work off the master drivers door switches.
Old Dec 1, 2005 | 10:36 AM
sdsdsd's Avatar
It sounds like a ground problem. You don't have a fuse in the circuit you have a circuit breaker. The circuit breaker goes in like a fuze but it is a silver little box, they do go bad sometimes.
south of cannel
Mar 9, 2014 01:24 PM
JoeCole
Sep 20, 2008 07:10 AM
timothy652
Apr 7, 2008 08:10 PM
gbliss
Oct 14, 2007 10:54 PM
vivalabui
Jun 2, 2007 07:40 PM
