93 roadmaster, 5.7L
Old Sep 16, 2012 | 05:07 PM
daveeski's Avatar
Default 93 roadmaster, 5.7L
been pulling a popup for years. this last time it started to overheat. i turned off ac, turned on heat, and made it 50 miles to campground. i then replaced the t-stat, thought i was good. on way home, it started to overheat again. suggestions?
Old Sep 16, 2012 | 07:38 PM
Merc6's Avatar
Last time radiator cap was checked or replaced?
Old Sep 18, 2012 | 04:05 PM
Some things to check out, radiator, water pump ,fan clutch, coolant concentration.
Old Oct 7, 2012 | 10:29 PM
DanielOlaf's Avatar
Old Nov 11, 2012 | 02:59 AM
bellad's Avatar
i then replaced the t-stat, thought i was good. on way home, it started to overheat again. suggestions?,。。。。。。。
___________________________________________
love me little,love me long!!
http://www.rsdgold.com/
Old Nov 24, 2012 | 01:31 AM
franklin53's Avatar
What does TBI OHV stand for or mean in reference to engines? And SFI DOHC?
What does TBI OHV stand for or mean in reference to engines? And what does SFI DOHC mean. I am talking about two different engines. The TBI OHV is a 93 Buick Roadmaster with a 5.7L V8 and the SFI DOHC is referring to a 2001 Chrysler Sebring Convertable FWD and 2.7L V6.
Old Nov 24, 2012 | 11:07 AM
TBI = Throttle body injection - could be one or two fuel injectors
OHV = Overhead valves
SFI = Sequential fuel injection - a fuel injector for each cylinder
DOHC = Dual overhead cams (some engines have only one camshaft to open both intake and exhaust valves, some have two cam shafts one for intake valves and one for exhaust valves and some others have the two camshafts on each bank like in "V" type engine
FWD =Front wheel drive
nate geezy
Nov 1, 2021 12:56 AM
kiltedscotsman
Jun 10, 2007 05:14 PM
bgisse
May 24, 2007 04:23 PM
mrhaney
Apr 2, 2007 04:47 PM
davestlouis
Oct 11, 2006 02:16 AM
