'93 LeSabre - How to remove wire hubcaps. Lock bolt turns?!?!
Old Aug 23, 2019 | 10:24 AM
Calab's Avatar
Unhappy '93 LeSabre - How to remove wire hubcaps. Lock bolt turns?!?!
So, I need to replace a rear ball joint on my 1993 LeSabre Limited... Right from the get go I have issues - I can't get the hubcap off!
Under the center cap of the hubcap there is a green anti-theft bolt. I don't have the tool for it, but I can get a pair of vice grips on it and turn it. No matter how much I turn it won't come out!
Is there something special you need to do to remove that bolt? Am I literally "screwed"? How can I get this hubcap off?
If I do get the hubcap off, will it stay on if I don't reuse the green bolt? If not, does it have a standard thread so I can replace it with a normal bolt?
Thanks.
Old Aug 23, 2019 | 05:26 PM
Sounds like the release tool may apply inner pressure to engage threaded part of bolt to turn. Could it rotate in reverse to remove?
Old Feb 8, 2022 | 01:53 PM
johnny56's Avatar
I know your post is a few years old, but could you tell me how you resolved this issue? Also, I can't figure out how to get the center cap off. Doesn't seem to be any indentation to insert a screwdriver to pry it off.
Thanks
Old Feb 9, 2022 | 10:44 AM
They don't always provide a spot for a pry off tool in which case we just pick a spot.
VanBuren
Jan 25, 2016 10:34 PM
wnlewis
Nov 15, 2014 04:36 PM
crazy_ndn604
Sep 23, 2008 01:01 AM
Casey8791
Sep 19, 2007 05:48 PM
banderz777
Jun 11, 2007 06:33 PM
