91Riviera Stall
Old Dec 16, 2004 | 07:45 PM
Cheech43's Avatar
Our 91 Riviera started stalling at stop lights, now it will turn over and run for a second and die. I have been told it was everything from my egr valve, to my fule filter, to my fuel pump... Once you get it started and hold the accelerator it will rev , but as soon as you take your foot off to drop in gear, it quickly dies.... help
Old Dec 17, 2004 | 01:44 PM
Erakiel81's Avatar
I ve got the same probleme with my regal 94. In my case it was the EGR
valve. I suggest you to make a good tune up also (change air and gaz
filter, spark plug and cable, check the charging circuit).
You can got an EGR valve used for not to much.
Old Dec 18, 2004 | 01:28 AM
Cheech43's Avatar
Thank you for your input, I was trying to change the fuel filter, i can not figure the darn thing out........
Made_in_Rus
Jan 10, 2009 10:12 AM
tbreezy
Sep 3, 2008 04:07 PM
BonnevilleGXP
Apr 11, 2008 09:13 PM
MrGoodwrenchGM
Nov 9, 2007 11:33 PM
cellulargod721
Mar 4, 2006 09:00 PM
