Our 91 Riviera started stalling at stop lights, now it will turn over and run for a second and die. I have been told it was everything from my egr valve, to my fule filter, to my fuel pump... Once you get it started and hold the accelerator it will rev , but as soon as you take your foot off to drop in gear, it quickly dies.... help
I ve got the same probleme with my regal 94. In my case it was the EGR
valve. I suggest you to make a good tune up also (change air and gaz filter, spark plug and cable, check the charging circuit). You can got an EGR valve used for not to much. |
Thank you for your input, I was trying to change the fuel filter, i can not figure the darn thing out........
