'62 lesabre rear main seal leak
Old Dec 24, 2012 | 09:04 AM
Ray Baker, Jr.'s Avatar
Default '62 lesabre rear main seal leak
Can I change the rear crank seal without pulling the motor?
Old Dec 24, 2012 | 03:34 PM
If it has the circular seal you will need to pull the trans. if it has the split seals that can be replaced with just the oil pan removed.
Old Dec 25, 2012 | 07:28 AM
Thanks for the reply. Fel-pro shows a split seal. I have some experience with in-frame repairs - head jobs, cam swaps, even a valve damaged piston w/rod in a Datsun truck. My next question is there a tool to remove the upper half and clean the groove?
Old Dec 25, 2012 | 03:59 PM
There is a tool that looks like a what we used to call a Chinese finger. It went on to the end of the rope/seal and as you pulled it it gripped the rope tighter. Some auto supply stores may still sell them. They may even have a newer type seal remover/installer.
Once the seal comes out there won't be too much of anything in there to clean out.
Those seals often became hard and refused to seal and had to be replaced. Let us know how you make out on this. Thanks
I am assuming you know you have to lower the rear main cap to do this and then you will see what the seal looks like.
Old Dec 26, 2012 | 07:37 AM
I think I remember a tool like that. Might've seen it in a Whitney catalog. I'll see what I can find. What with this leak, and some other minor issues, I'm considering pulling the lump. When it warms up later today, I'll get under her and see what it looks like. Thanks again for the info.
Old Dec 27, 2012 | 02:41 PM
You're welcome, and Happy New Year!
fullpwr5516
Jul 20, 2013 02:40 PM
schzjoe
Oct 2, 2012 06:05 AM
wuntun
Jan 29, 2012 12:19 AM
ibkevkeith
Jan 22, 2008 07:03 PM
ibkevkeith
Jan 22, 2008 07:00 PM
