1989 Lesabre door wont open help!
Old Jan 24, 2010 | 11:43 AM
XLR8's Avatar
Default 1989 Lesabre door wont open help!
hi everyone!
so i picked up a nice rusty trusty 89 lesabre 2 dr this week. it has a few problem i need help with though
1. The passenger door wont open. its unlocked, but it feel like something became disconnected in the door. i know how to take the door apart when its open, bit i cant open it! haha so how do i go about opening this door? any tips or tricks?
2. the fuel tank leaks when filled above half full(im thinkin there's a nice rust hole in it). if i buy a new tank, how hard is it to replace? i dont have a lift but i do have ramps and hydraulic jacks. if i do replace the tank, what all will i have to transfer over from the old tank to the new?
thanks everyone!! i appreciate your help!!
XLR8
Old Feb 3, 2010 | 11:36 AM
XLR8's Avatar
anyone? up!
Old Feb 23, 2010 | 12:51 PM
bob55's Avatar
You are going to have to work the door panel off. It can be done. As far as the fuel tank. Its not hard to remove. Just make sure you soak the bolts went penatrating oil.
Old Feb 24, 2010 | 01:57 AM
KMmailman07's Avatar
Question
I would take out the seat first. Then you can pop those plastic clips just as if the door was open (almost). You should be able to get the panel far enough away to get to the lever to turn or pull it and release the door. The other problem could be is the rust you mentioned. The door clasp could just be rusted and need a good donkey kick from the inside while you best friend holds the handle up standing out of the way on the outside. My son and I did that to a door on the back of my GMC van. Then we PB Blasted the lock and followed that up with chain lube. Never a problem since. As far as the fuel tank goes, What you see is what you get. Spray those bolts well in advance, may be twice or more. Drive the car till it's almost empty, easier than siphoning, safer too. Have fun. KM
jwaterma
Enclave
Oct 21, 2014 03:18 AM
wonderman12508
Aug 29, 2013 08:28 PM
david802
Jun 15, 2013 10:39 PM
paulsiegel
Feb 25, 2007 12:03 PM
Snoopy84
Feb 18, 2006 08:47 AM
