1992 PA A/C help.
Old Jun 27, 2007 | 05:17 PM
Matovy's Avatar
Can anyone explain how to correctly trouble shoot a/c problems? I have checked my fuse and its good I checked all the wires and they all seem fine but I am still not getting any power to the compressor. Does anyone know how to jump out the thermostat? I'm not exactly sure where the thermostat is.
Thanks!
any help would be appreciated...
Old Jun 27, 2007 | 09:04 PM
Matovy's Avatar
How about does anyone know where I could find the Ambient Air Temperature Sensor: A/C Ona 1992 Park ave
Old Jun 29, 2007 | 07:23 AM
bassasasin's Avatar
It may be the gas is low.
If the gas is low in the system it will not allow the compressor to pump. So adding some gas may make it turn on.
Normally there is a high and a low pressure switch for cycling. There is also a safety circuit that will not allow a compressor to run and burn up without freon/oil mix in the system. When you loose r134A gas from a slow leak, the oil remains in the system.
When
the system in normal, with enough gas present, the compressor pumps up
pressure till the high pressure is reached and it turns off, thus
cycling..
Try adding a can of freon to see if the compressor will start up. If
it does then check for a temp of 50 degrees, or lower at the vent while
on max cool.
Two cans should be all you need.
Do not add any oil unless something has been replaced, like the compressor or the dehydrator.
Hope this helps.
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
//-->The External temp sensor, on most models is on the center post in front of the radiator. If thats what you mean.
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Edited by: bassasasin
Drouse
Feb 28, 2015 11:36 AM
ole_school
Dec 10, 2011 03:40 PM
KillaCam
Jul 26, 2006 10:38 PM
gciuser
Jun 14, 2006 02:27 AM
Mike C.
May 23, 2006 02:21 PM
