Sputter and die!
Old Jul 1, 2005 | 07:03 PM
iowafixit's Avatar
Got a 1991 buick Century that ran great until it just sputtered and died. I have replaced the fuel filter and some vacuum lines plus on a suggestion I replaced the ignition modual with no results. I have fuel pressure and spark. After sitting over night it ran for a day then died horribly once again and i'm perplexed.I would appreciate any suggestions.
Thanks
Old Jul 2, 2005 | 01:50 PM
Erakiel81's Avatar
Check your EGR valve. This piece is often defect.
Old Dec 26, 2005 | 11:37 AM
SSEBonne90's Avatar
check all electrical connections, remove injector plug check for pulse when cranking with 194 bulb. (prongs bent down)
Old Dec 27, 2005 | 11:19 AM
Patrick's Avatar
Administrator
is the catalyitc convertor stock? before this started, did you notice any lose in power?
Old Dec 31, 2005 | 12:18 PM
SSEBonne90's Avatar
spark and fuel is what you check first.
Clacquam
Oct 25, 2014 01:53 PM
kianme
Feb 28, 2014 06:57 PM
kcotner
May 3, 2006 04:26 PM
