Electrical Problems
Old May 18, 2009 | 03:53 PM
tyre3d's Avatar
Default Electrical Problems
I have a 95 buick century with a 3.1l V6. It has been acting like it is starving for fuel so I figured that the fuel pump / fuel filter needed to be replaced. I installed a new fuel filter and the car did great for a several mile test run. I went to start it about an hour later and it started acting like it was running out of gas again. I pulled a fuel line loose and ran the fuel pump to make sure that the pump was running properly and verify that the gas was not compromised (debris / water) All was well so I reconnected the fuel line and pulled a plug wire to verify it was getting fire. When the car was started it ran a little rough (it was on 5 cyl) but when I reconnected the spark plug wire it acted as though there was a fuel problem again and died. This led me to believe there is an electrical problem. I traced down the ground from the fuel injection harness and cleaned it throughly and the car ran great for about 50 miles.....now it is doing the same thing. Any ideas?
mikeygrouch
Nov 15, 2011 01:56 PM
sharond444
May 20, 2007 11:29 PM
BuleJay10k
Jul 13, 2006 08:51 AM
kens1948
Mar 7, 2006 01:20 PM
tdufour
Jan 4, 2005 12:13 AM
