BF Help & Suggestion Center Need help with BF? Ask... Have a suggestion to better BF? Tell us here...
Buick Lesabre blower
Old Jul 31, 2011 | 01:20 PM
dandrews.bbc@gmail.com's Avatar
Question Buick Lesabre blower
I have a 1995 buick lesabre. We already replaced the climate contol unit in the dashboard and it worked for a while but the blower keeps stopping. It'll work a while then if we stop suddenly or honk the horn the blower goes off. The air conditioner is still running but no air comes out the vents. What else do we need to check out.
Old Jul 31, 2011 | 03:12 PM
There are 2 things you need to check. One is the blower speed relay and the other is the blower hi speed relay. When the control calls for blower operation the circuit goes through the blower switch , then through the resistor body then through a normally closed set of contacts of the blower hi speed relay. That's how the motor gets its juice.
The other way is when you select hi speed on the switch position, that energizes the blower hi speed relay and provides a direct path from the 25 amp fuse in the instrument panel fuse block to the blower motor. With these 2 things you should be able to pin down the cause for intermittent blower motor operation.
The relays usually are located in the relay center under the hood on the firewall.
ScottBostic
Mar 1, 2010 12:14 AM
drome
Apr 9, 2007 09:38 AM
SubieHo
Nov 30, 2006 07:31 PM
svofrk
Jul 9, 2006 06:33 PM
Dave42
May 23, 2006 02:13 AM
