blower motor problem
Old Apr 10, 2005 | 04:22 AM
svofrk's Avatar
I have a '90 Park Avenue with the "electronic climate control" option. The other day I had the AC running and the blower fan stopped working. I suspected a blown fuse, checked fuses-all O.K. Took blower motor out-tested O.K. I have replaced relay above blower cabinet, tried a new resistor module in blower cabinet, jumpered fuse link, tried my backup indash control keypad, still cannot get blower working. I am fit to be tied. Any help out there?
Old Apr 12, 2005 | 01:54 PM
Erakiel81's Avatar
Have you probed if any voltage present at the blower motor ?
If you have it may be the motor has a bad ground. Also check if all
contact are'nt oxidized. You may have voltage but almost no ampere if
you have bad contact. Hope it can help
Old Aug 11, 2005 | 11:49 AM
MrBSS's Avatar
I think it will stop working if the A/C charge gets low. I have a '92 Ultra (which I'm selling) that did that. As I remember, the read-out flashed also.
Old May 25, 2006 | 12:52 AM
xfrankiex's Avatar
check voltage at the blower motor plug.
Old Jul 9, 2006 | 06:33 PM
samueljackson's Avatar
jump the relay if no voltage going to motor.
hogster
Aug 6, 2008 09:56 AM
andersson
Jul 31, 2007 07:25 PM
drome
Apr 9, 2007 09:38 AM
SubieHo
Nov 30, 2006 07:31 PM
Dave42
May 23, 2006 02:13 AM
