Sights N Sounds Post Video and Sound clips here. This forum is for video's pertaining to Buick's, Racing (Street/Strip), Interviews, and Off Topic.
93,buick roadmaster limtd.
Old Oct 7, 2005 | 12:14 PM
nate geezy's Avatar
does anybody know how much horsepower that a93, buick roadmaster5.7L 350 L V8 have is it 180 or 260?
Old Jun 10, 2006 | 05:28 AM
Harley's Avatar
I would have to say neither, when you're thinking newer engines (like 90's and newer) we are talking something close to a hp an inch. Now a 5.7L v8 is gonna give you atleast 300hp or I'm a unkeys monkle.
but then again I'm a hairy son of a gun, so you might not wana trust me.
Old Oct 12, 2006 | 01:40 AM
samueljackson's Avatar
no, i think harleys right. i believe the lt1s put out about 300hp
Old May 25, 2008 | 11:21 PM
buickluver's Avatar
260 is the hp cause the impala ss used the same motor along with the 9c1 and it was 260
Old Feb 21, 2009 | 07:22 AM
BUMBUM316's Avatar
its all in the gearing though if you want to go fast
Old Aug 28, 2009 | 03:12 PM
AUDINE's Avatar
Love those corvette motors! Let some snickering kid pull up beside an old granny, then blow them away as I leave them in the dust.
Old Nov 1, 2021 | 12:56 AM
Fred Kiehl's Avatar
I realize this an old post, but though it would be good to have it clarified for anyone doing a search.
The 93 RM has 180 HP from an LO5 engine. They are TBI motors, and not the LT1 which has 265 HP. The torque output is 300 lb. ft. There is a version of the LO5 in some of the 93 Caprice 9C1s that have 210 HP. The only differences are the cam, injectors, larger Y pipe, and computer chip. It can be swapped into the RM with those changes. The 9C1 may have also come with a 3.42 gear with or without a posi. The rear housing for the 93 9C1 should bolt into the RM sedan, but it is substantially narrower than the wagon rear. The ones with a posi have a tag on one of the cover bolts. The SPID (white tag on the trunk lid/D pillar) code for the posi is G80. The SPID code for the 3.23 is GU5. I believe the 3.42 is GU6.
Some of the wagons have 3.23 gears with a posi, and some had 3.23 gears with an open differential, but most had 2.73 gears with an open differential. I do not think the 2.73 gear rears came with a posi.
Al9
Mar 18, 2018 10:35 AM
Fatgladiator
Oct 20, 2016 08:27 PM
Denise
Feb 25, 2011 03:04 PM
hermy
Nov 20, 2007 11:24 AM
nate geezy
Oct 21, 2005 11:26 PM
